RecordAceFromNew
Swinging Member
- West London
Well, after a bit of fettling I've got it in to what appears to be a working state.
Previously I was only running one chain-ring in the outer position of a double chainset. As RAFN suggested, my chainset is most likely ISO which moved it out 4.5mm on the JIS bottom bracket (still haven't figured out what that spacer is for, but there seems to be enough taper interfacing with the crankset despite it).
To combat that I moved the chain-ring to the inner position on the chainset, putting it back to roughly the right chain line. The outer chain ring position is now useless as it's too far out, but that doesn't bother me too much. It seems to shift well from the testing I have done so far.
It's not the perfect solution, but as this is just my around-town bike, if it works I'll keep it. If it doesn't work I'll just replace the lot with a new JIS chainset and matching bottom bracket to get it over with.
As I speculated earlier, your new UN26 122.5mm BB is indeed asymmetric. It is 63mm drive side and 59.5mm non-drive side, which explains the presence of the spacer.
One way to guesstimate whether chainset is indeed ISO is to see how far the taper goes into the chainset, some useful example photos here e.g.
In your case if your chainset is ISO and if the original 121mm BB is indeed ISO and symmetric your UN26 should give you (63mm - 121mm/2 +4.5mm) i.e. roughly 7mm or so more chainline than you want.
Further IF the chainset is no different to modern ISO, and if the original 121mm BB is ISO and symmetric, I would expect a new Shimano JIS 110.5mm (sometimes marketed as 111mm) BB should give you practically exactly the same chainline and clearance as previous (+/- 1 or at most 2mm), since it is: a) practically symmetric, and b) nearly 9mm (i.e. 2 x 4.5mm) shorter than a symmetric 121mm ISO one. You can of course also try to hunt down a 121mm ISO BB, or indeed as you said change the whole lot to something that is self compatible and delivers the correct, desired chainline.
