Yesterday, I went to the gym at lunch.
I ran interval sprints on the treadmill:
12.0 Speed
60 Seconds running
30 Seconds rest
.........Repeated the above the 10 times
After the 8th sprint.........I couldn't feel my legs.......Its a great cure for Happiness ...But.....
......How effective is the above for weight loss ? ( I Must add that before I did the above I ran 3k)
IMO, whilst many people like Jimbo will dazzle you with the science of calorie burning and tell you what muscles etc get brought into action by this and the other nuance of form, which is excellent, if not partly impractical for a newby to running.
I will offer a radical alternative opinion. You shouldnt bother with any sprint intervals at all right now. If you are new to running, the muscles and tendons used differ and/or are used differently in running than cycling and whilst your aerobic system may improve quickly, the tendons etc will not adjust at anywhere close to the same rate. Starting off running with sprint intervals, hill sprints etc is just asking for trouble.
Forget about your arms, bend them at rought 90 degree's at the elbow and let them swing naturally like a pendulum, the only thing you should really think about is making sure they do not cross your centre of gravity sideways whilst swinging.
Your plan is potentially a recipe for disaster if its done more than 1-2 times a week and not supplemented with other quality running sessions if I'm honest. 3km run followed by 10 x 60 second hill sprints, how many times a week are you planning on doing this? This is not a weight loss plan, its a middle distance runners speed session (As a side note: If I were going to do this session I'd run 1 mile warmup run, then do the sprint intervals, then 1 mile cooldown run, not run 3km then do an intense sprint interval workout as the closer).
I would suggest that you simply run at a comfortable pace 3 times a week for 20-30 minutes for couple of months (dont worry about speed, worry about your form and making sure you pick up good habits now so you dont have to unlearn bad form later, your speed will naturally increase over time but dont push for it) and increase your running distance by no more than 10% per week. You will still drop the pounds, maybe not as fast as with sprints, but at least you wont end up injured and unable to run for weeks/months and putting weight back on due to inactivity.
Also, consider popping down to one of your local parkruns for a no pressure 5km timed run, lots of friendly faces of all fitness levels from the nutcase finishing in less than 16 mins to the shufflers rolling in at 40+ minutes. There is a number of them around Manchester, every saturday morning. If you come to South Manchester (Platt Fields) I will be around doing the runner registration etc.
