- South Manchester
Internal cabling done badly can be a rattling nightmare however I have one bike where the rear brake cable runs inside the top tube but this isn't done simply. Someone has gone to the trouble of brazing a thin tube inside the toptube from an angled recess behind the headtube to a similar exit point just in front of the seat cluster. When I got the frame I just thought it had been drilled for the whole cable to run through but no it wouldn't fit so I got a torch out to have a peer and the hole is closed off with a 1mm hole in the centre so I poked an inner through this thinking what a hassle it could be to find the other end and tweeze it through the exit but the end just popped straight out by the seatpost so there has to be an internal 'tube' the inner runs through inside the toptube. This must have been an incredible amount of work to accomplish cos not only the oval appertures are exactly the right size to accept outer cables with a ferrule but then to have the other end finish so neatly with the same fitting is mind boggling, it must have took hours of precision work to achieve but then the 'seat cluster' shows a similar amount of attention to detail
You can just about see where the brake cable emerges but I don't have a piccy of the other side of the bike (and I'm not trying to dig the bike out of the shed at half twelve on a Sunday night)
BTW when I bought the frame it had no decals other than the 3 '653' stickers, has no headbadge or frame number so I have no idea who made it but the workmanship is superb
Both my old road bikes have internal rear brake cables. Both are done with an internal 'pipe'. One has a 'pipe just thin enough for the inner, so has ferrules on each end, the other the outer and inner is inside the 'pipe'.
