Not quite true. The way the brake cable exits the bar(tape) is important. A sorted internally routed cable will exit more cleanly & be heading towards the back of the bike/has a shrouded exit so air flows cleanly over the cable exit. This results in dramatic drag reductions at the cable exit which is where the majority of drag caused by the cable is (loads of turbulence) assuming that you have aero tops (which is one of the primary reasons for internally routed cables) a non-taped tops is much more aero than a wrapped top with cables. As I said you're getting into the details.
