Alex321
- South Wales
I have internal cable routing on my bike (Cube Attain GTC Race 2021), with Shimano 105 R7000 drivetrain.
I've been having issues with the front change to the large ring recently, and after a bit of fiddling around, though it was most likely the cable, so went to change that today.
But there seems to be an issue, in that I believe the outer sleeve is supposed to be attached to the inside of the hole in the frame, so you can just push the inner through. It appears to have become detached (which may be what caused the whole issue in the first place), soo I can't push the inner cable through the hole, which is too small to be able to see through, never mind stick anything in to try and snag it.
I think I'll be taking it to my LBS tomorrow, but how can this issue be fixed? Can you get at the sleeve and that hole form the inside if you take the Bottom Bracket out (press fit, so I can't just do it to have a look). I have neither the tools nor expertise to deal with a press-fit bottom bracket.
And is there likely to be something inside the hole to attach the sleeve to, or will it be a case of something like superglue? It is a Carbon Fame if that makes any difference.
