Interesting and informative pictures
PeteXXX
PeteXXX
Photo Winner
Hamtun
E&OE
markemark
Would this vary according to how close you are to the equator?
Imagine it does because I’ve often noticed how quickly it gets dark when travelling in countries further south.
Edit found this.
There are several factors that alter the accuracy of this including latitude and time of year. The farther you are from the equator, the less direct the sun travels from its position in the sky towards the horizon, especially in non-summer months. In summer months it follows a nearly vertical line from the sky to the horizon as it sets, making the last few hours of “finger reading” very accurate. Whereas in the winter, it angles more towards the horizon, so you’ll have to line your fingers up along an estimated angled path vs. a straight up and down path. But if you forget that part, you’ll actually be underestimating the amount of daylight left, so you’ll be erring on the side of caution anyways.
Widnes
I have heard that near the equator the sun sets very quickly - up by the poles it is very slow
which makes sense becuase it had further to go at the equator
whether or not this is correct is another matter
markemark
My quick research is that the sun travels through the sky at a constant speed irrespective of season or latitude. However the time for sunset varies as to both above as the path takes is more or less angled to the perpendicular. Eg at the equate the sun drops directly down further away is goes the same speed but at an angle do takes longer to reach the horizon.
Widnes
That's what I thought - just didn;t have the interest to find out properly!!!
