Installing a shimano 6/7/8 speed chain
Wester
I am going to fit a new Shimano chain to my bike and there is something that I am not sure about
Do you need a new pin when you shorten a Shimano chain ? when I opened the package there was only the chain and a power link no pin . Or can you shorten it in the same way as any other chain
Any advice on how to install a Shimano chain
biggs682
Northamptonshire
You should be able to shorten as normal and re connect using a quick link
Wester
Wester
I have joined the chain using the quick link for a test to see how it works before I put the chain on the bike I joined it ok but now I cannot open it again to put it on the bike
Any advice
gbb
Peterborough
Any advice
If it' the Shimano link I'm thinking of, you need to bend the chain either side of the link, the quick link side lates will bend, shortening the distance between pins and allow the plate to release....its difficult to explain, easy to do.
