Nigeyy
- Massachusetts, USA
Well, having owned inflatable kayaks.... I can't remember the brand, but it was a pretty good one. However, tracking is always more difficult than even some cheaper plastic kayaks, certainly in windy conditions. After about a year (just past warranty!) it sprung a leak, and no matter what I tried, I couldn't get to seal the leak which was near a seam in a place I just couldn't get easy access to. I did end up throwing it out a couple of years ago as it got worse and worse....
My advice is if you positively don't have storage for a rigid kayak, then obviously go for it. There is no doubt that being able to pack it up for transportation is a huge feature -and this may be the only way you can get out! Add in the fact you obviously don't need inflation bags for the kayak However, I do think inflatables have much less of a lifespan than rigids, and depending on use, I wouldn't bank on more than a couple of years of use. Assuming you aren't buying a top of the line inflatable (and even then I'm not sure) I would say avoid the ocean (certainly when there are lower temperatures) or rough water. Cruising along a canal, gentle river or pond is fine, but I don't think these are for rough water. Mind you, the kayaks I have are cheapie ones and I wouldn't dream of going out on the ocean with them either, but obviously there are some proper ocean kayaks out there.
To summarize: if you can buy rigid, I'd say do so. Otherwise, buy an inflatable but know there's more of a limited lifespan.
