Indexing problem
rich p
rich p
ridiculous old lush
Brighton
Well, well, well. Humble pie for lunch and a big smoochy kiss for AFS :smooch: . The new cable has done the trick.
Stand down troops!:cheers:
MacB
Well done mate, glad you went through all those hard bits rather than just spending a couple of quid on new cables to start with :whistle:
In seriousness, for a regular use bike, I'd be tempted to replace inners and outers every Spring, just using cheapish bog standard stuff.
rich p
rich p
ridiculous old lush
Brighton
Cheers Al. I'm pretty sure I changed both earlier this year but it may have been my old memory playing tricks! A lesson learnt though and I'd only have been lounging about eating pork pies otherwise.
zacklaws
Beverley
In theory you should change outers at the same time as the inners as I have just found out as I have just had similar problems, but it was not all down to the cables as I also found out my hanger was slightly bent causing me "auto shifting".
I suspect I may have bent my hanger when I pulled up onto some ones lawn to let a car pass, and as I very slowly went down a slight slope sideways to get back onto the road, my wheels slid out sideways from underneath me and I had an involuntary lay down on the lawn on my right hand side. Sand was what caused my wheels to slide away from me. Another lesson learnt!
potsy
Rambler
My Armchair
Have you got a bike that gets 'regular' use then Mac?
Last time my gear changing was getting poor, new outer cable worked wonders. Will now do what you suggest and change mine in the Spring eavh year :thumbsup:
