lulubel
- Malaga, Spain
I've looked at it again.
The chainline is exactly 45mm, so that's fine.
I've had a good look and a poke around with a tiny screwdriver, and I can't find anything lodged inside.
Considering the chainline is correct, here's the weird thing. With the limit screws as far out as possible and no cable attached (ie the mech in "normal" position), if I put the chain on the middle ring and turn the cranks, the chain will not drop onto the granny ring unless I angle the back of the cage inwards towards the frame slightly. If I did that on my old bike (or any other bike, for that matter) the chain would be immediately thrown onto the BB.
Is it reasonable to deduce from that last paragraph that the mech is broken? (Or faulty, I suppose, but I have to assume broken after what I did to it.)
There wasn't a spacer, but apparently I didn't need one. (I'ce checked the manual online.) The chainline is correct.
Thanks for the definitions. Knowing terminology makes it a bit easier to explain things too. I can actually use the correct term rather than trying to explain what I'm attaching to what or which bit I'm measuring!
Have you built this bike up from scratch? Or what set up was it previously?
I have recently fitted a Tiagra triple chainset in place of a compact set up and it came with a black plastic spacer which sits on the axle on the drive side, this is to give the correct chainline for the triple and to ensure that the granny ring doesn't catch the frame. Is your Sora chainset the same? Did you fit the spacer?
Lulubel, sorry assumptions made and terminology gets chucked about:-
