ChrisEyles
- Devon
I'm being inspired by the "no question too stupid" tagline on this forum, so treat me gently on this one!
I've just bought a new bike for commuting. It's both the first index shifting bike and the first triple crankset I've ridden since I was a kid, so there are a couple of points I'm unsure of about shifting between the gears.
1) On my old 10-speeds I've been perfectly used to avoiding low-low and high-high gear combinations. Question now is, with a triple, where the chain angle can be much steeper, how much of the (8-speed) cassette should I be using on each chain ring?
At the moment I've been going with:
Large ring (48t) - sprockets 4-8 (err 23t-11t I think)
Middle ring (38t) - sprockets 3-6 (26t-17t?)
Small ring (28t) - sprockets 1-5 (32t-20t?)
On a pleasure ride I'm mostly on the largest ring at the front, commuting it's more of a mix between large and middle. Small ring is of course for bailing out, but I have been glad of it already. If it makes a difference I tend towards a cadence of around 70-90 rpm (and am working on increasing this a little more).
This gives me the full range of gears with little to no overlap... but am I being too conservative here? Am I in danger of being so fixated on a nice straight chainline that I'll end up prematurely wearing the small sprockets on the cassette? Or does it not even matter? Would be great to have this cleared up!
2) I miss my friction shifters... while I'm sure I'll come to love the integrated shifter eventually, right now I'm missing any kind of tactile feedback when shifting gears. In particular, if the shift doesn't happen immediately it's annoying to have to slacken off the pressure on the pedals until the shift happens, whereas on my friction shifters I can simply tweak the lever to force the shift. I tend to end up shifting e.g. up two then down one to change up one gear.
Is this merely something to be endured on an indexed triple, or should it be possible to set up the derailleurs to give smooth and instant shifting (if so it is certainly beyond me at the moment, but it may warrant some further research or another trip to the LBS)?
Any pointers greatly appreciated - and if the best advice is "stop worrying about it and just ride" that'd be equally good to hear!
