marzjennings
- Houston, Texas, USA
jimboalee said:I'm going to try 180 rpm on my slicked up MTB tonight.
36" gear at 19.5 mph. Api Sapis, I expect.
I usually ride that speed on 78" at 83 rpm.
What would happen to my HR if I tried 180 rpm on the 78" gear?
42 mph.....
You're guess is as good as mine, because HR is not related to any other metric.
What you are getting confused with is 'HR and exertion follow a trend'.
HR increases as exertion increases. If you try to put numbers and equations on it, you will have to recalculate the curve fit coefficients after you have improved your fitness just a little.
Maybe on a weekly basis.
Then YOU will have a frig factor for YOU, for that moment in time. Your frig factor will change after your next training session.
I'm not attempting to mathematically connect HR and cadence, but I do think the correlation between increasing cadence and increasing HR is indicative of a cause.
To your example above I would 'guess' that for a given speed of 19.5mph your HR will be higher pedaling at 180rpm at 36" than at 83rpm at 78". You really don't think this is a logical relationship?
And to your question; it'll be higher, with a 90% probabilty.
