Pale Rider
You could try degreasing/deglazing the rotor and pads.
Grit is ideal, an old mountain biker's trick is to smear mud on the rotor and use the bike as normal.
You might notice the brakes pull a bit better after you've hammered along a cinder track - it's the same self-degreasing effect.
If you don't fancy that, a mildly abrasive kitchen cleaner - Cif or similar - applied with a dry rag to the rotors would do.
Or fine grade emery cloth.
