One thing to consider with Spyres is the inner arm runs  very close to the spokes on the front wheel with a 160 rotor, if you put a bigger rotor on with a spacer for the caliper it gives you a bit more clearance.
You sir are a genius!
I have had a strange ticking noise from the front brake when braking hard, sort of like a spoke catching. I have looked at it a few times, checked everything is tight, made sure there is plenty of room between brakes and spokes, looked at the rotor to make sure there is nothing odd about that. Just couldn't see what it was that could make the noise.
Your comment just gave me an 'I wonder' moment. It turns out there is a feint scuff up the back of the brake caliper where the magnet for my cycle computer touches it. There must just be enough deflection of spokes and fork under heavy braking to make them touch, hence the annoying tick once per wheel revolution.  Very surprised i didn't spot it before. At least I can stop worrying now.
