PpPete
- Chandler's Ford
I presume we all agree that comparing 1x1 with Nx1 is like comparing apples and oranges.
Regarding chainline, while #speed dependent chainring spacings are roughly 2x that of rear sprocket spacings. That means by centering the single ring on the rear chainline in the worst case scenariois a Nx1 arrangement should offer better lines by 1 rear sprocket compared to a double, and 2 rear sprockets for a triple.
I'd disagree about the triple... your single ring would be in the same axis (pretty much centered on the cassette) as the middle ring of a triple - wouldnt it ?
Not saying a 1 x 9 (or 1 x 8) wouldn't be perfectly fine for many less than hilly rides, -or for a commute that you know really well, as MacB suggests, but in the interests of chain wear I think I'd still consider using the limit screws to lock out the the largest & smallest sprockets. OTH if it's not that hilly why not just MTFU and ride fixed ?
For myself I use fixed on shortish local journeys where I know the terrain, but no way would I change from my triple for longer rides, audaxes and the like. On last weekend's Dorset Coast I needed my full range 25.5" (for at least 6 of those hills a bottom gear of 30" would have had me walking) and the 108" to try and make up for lost time when going downhil (max recorded was 67 kph), and the close ratios (6% - 7% gaps) for the flatter start & finish sections.
