No. I originally bought the bath to remove solder flux residues from small production batches of printed circuit boards. It subsequently proved handy for cleaning my chain and cassette when used with a different solvent, Jizer.What's wrong with a brush and elbow grease. Works on MTB mech which get invisible through mud. Ultrasonic bath. Middle class crisis hey ?
After the Jizer, I wash the bike bits in the US bath with a fairly strong detergent solution and then repeated rinses with clean water. I then stick the bits in our oven in the kitchen for about 45 minutes at 70C before re-lubing.Jizer is an excellent degreaser - it is water rinsable and also a corrosion inhibitor. It cleans Aluminium really well. With regard to your rear mech or cassette I would use the ultrasonics - however, I would agitate it regularly in the Jizer to flush any dirt out.
Drain and then lubricate. It will be o.k. with most plastics - and will be really good for chains - I would put it in the tank - but use a brush as well on the plates and between the links - drain and lubricate.
I took off the rear mech today, gave it a wipe, and looked at it in detail. All the pivots that the parallelogram action has for lateral (shifting) movement are pretty straightforward to re-lube after cleaning. However, the main swing pivot that tensions the chain (and has a fairly powerful torsion spring) might be a bit of a problem to get grease into. Campagnolo say that attempting to dismantle it could cause a problem. I got cold feet about lobbing it in the US bath. Am I being too cautious?Yes, go ahead and do it. An ultrasonic batch is great for all parts, including shifters - STIs, Ergos, the lot. All you will have to do afterwards is remove the idler wheels and dry the axles/bushings and lube them inside there. I have no idea what Jizer is but any soapy degreaser will do, no need to use a petroleum product - dangerous in an ultrasonic bath in anyway.
As for cleaning shifters in such a bath, Shimano products are fine but Campag Record ergo levers have a ball bearing inside that requires special attention once it's been in such a bath. I just disassemble it and rebuild from scratch, using the ultrasonic bath to clean the individual parts.
The ultrasonic bath works perfectly for chains as well, I use it primarily for that.
Yes, you are.I took off the rear mech today, gave it a wipe, and looked at it in detail. All the pivots that the parallelogram action has for lateral (shifting) movement are pretty straightforward to re-lube after cleaning. However, the main swing pivot that tensions the chain (and has a fairly powerful torsion spring) might be a bit of a problem to get grease into. Campagnolo say that attempting to dismantle it could cause a problem. I got cold feet about lobbing it in the US bath. Am I being too cautious?
