Chuffy
- On the banks of the Exe
Is it possible to add an Ignore Board feature to the software? I wouldn't dare suggest scrapping Soapbox, nice though that would be, but it would be useful to be able to simply Ignore it.
Er, I think so. I don't use the new posts thing myself, I just look at the main page, but anything that makes Soapbox less visible has to be a good thing. Cheers Shaun.Admin said:If I'm understanding this correctly, the ignore part of the request actually means hide?
For example when you select new posts, it would hide the new posts from the forums you don't want to look at, and would also remove the ignored forums from search results, etc.
Is that what you're after?
If so, I'll have a look at the VB forums to see if there is a plugin/hack that can do it.
Cheers,
Shaun
Crackle said:I started a debate about swear words a while ago.
http://www.cyclechat.co.uk/forums/showthread.php?t=7563
Most were against moderating them because drawing a line is such a difficult issue.
Anyway, AM would be rendered speechless if there was a swear filter....................Actually, it is a good idea.
As I said before, it simply puts off people who, for whatever reason, don't want to download long strings of expletives while browsing the forum.I think you're mostly right mjones. The problem with having an unmoderated area, not publicly viewable, is that it's a bit of a self-fulfilling prophecy. Build it and they will come, so to speak. I would have thought/hoped that you could have serious debate and casual chat within the same area, eg the Cafe. That's the way is used to be on C+ and it seemed to work, the serious threads were pretty much self-modding. Soapbox always had a reputation as a bit of a bear pit from the day of it's creation on C+ and it's got worse since. That's not intended as a knock at the way Shaun has set this place up, but maybe it's worth having a bit of a re-think. I don't think it adds anything of value beyond giving people who have little or no interest in anything else a venue to knock lumps out of each other (see the current Bunfight between Linford and Absinthe Minded for example...)mjones said:It shouldn't be necessary, but unfortunately a small minority of members are abusing the freedom of the forum. I don't see why the tone has to be set by those with the lowest standards of behaviour.As I said before, it simply puts off people who, for whatever reason, don't want to download long strings of expletives while browsing the forum.
