Ningishzidda
Victoria Pendleton.
The problem is when you also ride like a rugby player!Good job I look like a rugby player and not a cyclist then!![]()
It is impossible to say whether you are overweight just from your height. You might have anything from a very heavy build to a very light one.
So, try an experiment .. (For the sake of modesty, let's assume that you have a pair of boxer shorts on) ... Jump up in the air while looking at yourself in a full-length mirror and tense all your muscles. When you land, can you see anything wobble?
If the answer is 'no', then you probably don't need to lose much weight, unless you are one of those people who stores a lot of fat internally.
If the answer is 'yes' then you have surplus fat and could definitely lose some weight. Surplus fat doesn't help your performance so losing it wouldn't hurt your performance.
If you don't cycle up a lot of hills then a few pounds here or there isn't going to make that much difference, but if you do a lot of hills then every pound lost will help as long as you don't overdo it and lose power.
errr..... i have this 'mate' and he did this experiment yesterday and its still wobbling, what does that mean?
It means he either needs to stop jumping, or to jump up and down millions of times and burn away whatever was wobbling!errr..... i have this 'mate' and he did this experiment yesterday and its still wobbling, what does that mean?
Which is why, in general, rowers and rugby players are a lot hotter than cyclists![]()
For some reason when I look at these pictures, I'm not convinced its the scrawny guy who has problems with the ladies![]()
No, these are before and after photos ...!Are those before and after pictures?
ill do that, err i mean ill tell himIt means he either needs to stop jumping, or to jump up and down millions of times and burn away whatever was wobbling!
im the other end of the scale and i also cannot climb ha haI'm 5'9" and 8 1/2 stone and can't climb for toffee. Whenever I meet new people on the bike they always say that I'm like some sort of racing snake and that they'll have to watch me on the hills. Then always seem bemused that I'm one of the worst climbers in Yorkshire (a slight exaggeration, but only a slight one). I find that if I can get my weight up to 9 stone, while keeping my fitness up, I ride much better. I can't maintain that weight though, I have a job, I can't actually spend all day eating, which is pretty much what it takes.
