mikeymustard
That's the sign of a good machine when you just want to keep going
panaracer pasela's ? gum wall and ride well IMHO. Its what I run on my ex Martin Peugeot.Took your advice Martin, ended up taking six links out before it stopped skipping, also had to replace the rim tape after the front tyre went flat, it had gone brittle with age and was well past its best. Changed the tyres as well while I was at it for some Vittoria pro but they don't look as good as the gumwall ones so may look out for some, any suggestions other than the Michelin dynamics?
Your not the first person to mention the panaracer tyres, although I had forgotten about them so thanks will look into them especially as they seem to be available in sizes larger than 23c
I love that subtle paintwork detail in the white and yellow.
May I ask what they're like to fit/remove? I've heard they're lever breakers which with the likelihood of punctures has put me off before now.Veloflex Masters come in 25 mm. I have not had mine long but I can say two things, they roll VERY well and they get cut VERY easily. If you want a Sunday best tyre gum wall then great, if you are looking for something day to day then probably not.
Ribble and Wiggle both have them at a sensible price and you can get them in blue![]()
Thanks, they do look great as well. HmmThey are![]()
To put on initially. The guidence is not to use levers and so I thumbed them on: the first was a long painful process, the second a shorter painful process
. however, I am a soft southern office worker and your pain threshold may vary. Touch wood I have not had reason to take them off yet.
In terms of on the road repairs, I am thinking of getting one of those cans with the gunk that seals and inflates and then worry about the rest when I get home.
Is it worth the faff? Subjectively they are much better than the Vittorias which were on it before and certainly contribute to the feeling of "want to jump on it and ride it"
Just done a nice 26 miles on IMC044 i think the longer stem swap is just about spot on for comfort wise although i am just looking ahead of axle line i dont think it needs swapping so just need to swap the bar tape and cables over and thats it
