Deleted member 121159
Two observations on the image you share, which you can read across to your cunning plan.
This guy has their braze-on FD at its fastening positing limit. And the cage is too high (because they can't get down far enough, I assume, not ignorance). There should be a maximum of 1mm between the bottom of the cage and the tip of the large ring teeth. With your band-on, this should not be an issue.
This is a 39t large ring. Your plan is for a 36t. So the curvature of your FD cage (designed for 46t+) will mean it's a long way away (along the chain) from your new small ring (?26t) engagement tooth and therefore changing will not be as 'secure' (it will work).
You may wish to consider a chain catcher.
I see what you mean now. I hope that the difference in curvature will not be a massive issue. After all, a road FD is supposed to handle 50t to 58t front chainrings. (58t here)
. My daughter is only running a 56 (with (sort of) braze-on (no brazing involved)).
