Fantastic idea! Will do, thanks for that! Love CCHow about getting some of that pipe insulation stuff and cushioning the crossbar. Just in case![]()
There can be, because the rest of the bike won't fit right. Basically they are trying to sell what they have in stock, and the most common size is Medium (ie. 18" for MTB). You need a smaller frame than that.Thats the problem, the 18 inch frames I tried sitting on is the smallest size they do. But if I am able to just about touch the ground with the very end of my toe while the saddle is at its lowest, is there anything wrong with that?
No, you can't fit a 26" tyre to a 27.5" wheel. If the bike has disc brakes, then changing to 26" wheels might work, but don't do it in an attempt to make a bike fit you.Thanks for all the answers. Its a road or hybrid which I'm looking for, as I'll be using it to go to places around the city.
Do you guys know if I can fit a 26 inch tyre on a 27.5 inch wheel? if not, can I fit on 26 inch wheels?
No, nothing at all. You can slip forward and dismount when stopped. After a bit you'll find that you can use the first pedal downstroke to lift yourself back onto the saddle. That in itself is no problem: the important things are whether the distance between saddle and pedal is so large that you're having to roll your hips just to get past the lowest point, and whether you're overstretched between saddle and handlebars.....But if I am able to just about touch the ground with the very end of my toe while the saddle is at its lowest, is there anything wrong with that?
Oooh, you don't want to bash your below. When I was about 12, I had to jump off my older cousin's bike in a hurry and broke my pubic bone. You really really don't want to do that.
@Thursday guy the smaller Giants are really good, as are the small Treks. I have friends who are a good 4" shorter than me with Giants and Treks and they love them.
In that case...
http://www.decathlon.co.uk/triban-300-road-bike-white-id_8239800.html
That takes some beating as budget road bikes go and available in small sizes.
Or perhaps start with flat bars in London if you've never been on the roads before
This is a bargain, 51cm should fit
http://www.decathlon.co.uk/fit-300-flat-bar-road-bike-id_8306479.html
Including those two bikes you both have posted, which do you think I should get?
