Cool, just be careful. In case you didn't know, most of the stopping power on a bike comes from the front brake, due to the weight distribution shifting under deceleration. That's also why the front blocks wear quicker than the back.Believe it or not, I've not had time to sort them yet, so I'm just using the back brakes and not relying on both for the time being.
A what-ee?Get a fixie,problem sorted.
Eh?Not strictly true. For example, the smallest sprocket on my bicycle has eleven cogs.
Yep.Eh?
So, on your block, you your smallest sprocket, has eleven little cogs somehow attached to it?
Well I never.Yep.
cog
Definitions
noun
- any of the teeth or projections on the rim of a gearwheel or sprocket
Oh my god...it's true.Yep.
cog
Definitions
noun
Heh. Extra smartarse points for meOh my god...it's true.
But....we...I...it......er
I nicked it off the internet. When we went there was a really annoying family who kept getting in the way of all our photos. And I was feeling the effect of the altitude a bitCracking image!
 . The views were stunning though.
. The views were stunning though.Credit where it's due...Im a photographer and would be proud of that image.
The irony of this discovery in a thread about ignorance isn't missed on me.Heh. Extra smartarse points for me.
In case the op's confused, and for the benefit of any other beginners, what @jonny jeez and I are bickering about are the names for the different gearwheels on a bike. The ones at the front, which are turned by the cranks as you pedal, are called chainrings. The ones at the back, attached to the rear wheel, are called sprockets. Some people call them cogs which is incorrect, the difference being that a sprocket is driven by a chain, like on a bike, whereas a cog or cogwheel is driven directly by another cogwheel, like in jonny's grandfather clock. Cog is also the name for a tooth on a cogwheel or sprocket, but is only used in that context by smartarses on internet fora, everybody else just calls them teeth.
So, chainrings at the front, sprockets at the back.
As an aside, on honeymoon we went up Pike's Peak on the cog railway. It's got a rack of teeth(cogs) along the track and is driven by a cogwheel in the train which enables it to climb the steep gradients without slipping.
