Yellow Saddle
- Loch side.
I had links left over from ahortening it when new i had far too many links on it
OK, you had links over and you used those to patch the chain. This is clear to me now. How did you fit those links by not using a Shimano link pin or a master link of sorts? On ten-speed you cannot re-fit a pin since it is damaged on its way out.
The pin on the left is a nice example of a brand new pin that was pushed out. At the top is the undamaged peen, at the bottom is the broken peen.
Here's a close-up of a chain breaker pin with the broken peens from three or four chain pins still attached to it.
A chain with a re-used pin may look OK but it will have no lateral strength at all. How did you mend your chain?[/QUOTE]
