MacB
- Farnborough, Hampshire
Any general info useful but I do have some specific requirements around something I'm trying out. It means that the brake lever must have a two bolt or hinged clamp to work. So far the best I've come up with is the Deore M595, complete with rotors, for £120 from Merlin...these are the requirements I'm looking at, but I'd be happy to be educated on any of it:-
clamp - prefer hinged over two bolt as the least amount of protrusion above the bar the better, hence the Deore over the SLX
fluid - the hydraulic set I have is the Tektro Auriga that uses mineral oil, for some reason I'm drawn to mineral oil over DOT fluid but not based on any actual knowledge
rotors - road use only so 160 front and rear should be fine, anything else I need to consider, ie are some makes more likely to be true, last longer, etc
pads - ease of replacement(tool less), availability, I naturally lean towards sintered as I consider rotors, as long as they're not too expensive, disposable items
maintenance - I'd like to get a set that come pre bled etc, just ready to go on bike. But if, and when maintenance is required I'd like it to be as easy as possible. Fit and forget would be nice though
performance - I have very limited hydraulic disc experience but remember this set is for road only use, with road tyres, so super dooper downhill capability not a requirement
lever blade - I don't see detail on length of blade but would like to get longer, rather than shorter, if possible, or can you change them after the fact? The brake position will be about 2/3rds of the way along a grip area to allow braking from front of grip area, the longer the blade the easier it will be from the rear position
value - I don't want to get anything uber expensive but I don't want to go so low end that I'm always hankering to upgrade or constantly having to tinker...the weight is not a factor within reason.
Oh, and anything else that I've missed out as I know naff all on this subject....cheers
