Should be fine if the suspension has a lock out, I just find it too bouncy even locked.
Sure you’ll enjoy the new bike
Make sure it’s fully insured if buying on C2W, home and away
edit just seen no lockout as it’s a budget model. I’d avoid myself but ymmv
Thanks!
wouldn’t this suggest that the suspension is adjustable meaning you could also possibly lockit?
“ADJUSTABLE SUSPENSION FORK
The Riverside 500 is equipped with an Odessa OS suspension fork with preload adjuster (1-1/8" steel pivot). The stiffness can be adjusted using a simple adjustment wheel.60mm travel.”
