accountantpete
OAP
The grease soon spreads away from the contact area on the race on the cone and hub - that is normal.
Any old grease will do - some are a bit smoother than others but all do the basic job.
The one thing you need to master is the tightening of the locknut. You can't simply tighten up the locknut to the cone.
You need to tighten up the cone so that the bearings just start to feel rough (ie overtightened). Then tighten up the locknut right up to the cone.
To finish you then simultaneously undo the cone and tighten the locknut into each other.
This provides a "lock" which keeps everything in place and should also slightly undo the cone - meaning that the bearings no longer feel rough.
It takes a bit of practise to get the wheel just right as regards the free rotation of the hub with no play.
