Cubist
Still wavin'
- Ovver 'thill
[QUOTE 3747988, member: 9609"]you're in ambiguous mood today - No to my question or No it doesn't slide[/QUOTE]
The majority of modern hydraulic disc brakes have two opposing pistons, both of which move in order to put the pads on the rotor. Some have four pots, two on either side. These tend to be more downhill oriented. Hope had some four pot versions with elongated pads. They were a royal pain to set up as the caliper had to be perfectly aligned.
Unlike the cable or BB operated mechanical brakes which have a fixed side and one moving piston, current hydraulic brakes don't need to be adjusted as the pads wear, and caliper/reservoir design means they stay at an optimum distance from the rotor once they have been bedded in. The hatred for Elixir and many other Avid hydraulic designs, stems from the fact that they are very difficult to setup without rubbing, singing or simply losing power. They had a complicated system of conical washers on the mounting boltsto align them correctly, and these were not very home mechanic friendly. They are difficult to bleed .
Modern Shimano versions, Deore, SLX, XT and XTR are easier to bleed but most importantly employ a servo-wave lever, which means that the pads can sit further away from the rotor, virtually eliminating unwanted rub, even with a fair bit of rotor runout. The first touch of the lever on a well set up system brings the pads close in, then the rest of the lever travel modulates very nicely.
