Yellow Saddle
- Loch side.
Yes and no. They have thin-walled, solid-wall tubes.Are carbon frames solid?
Some carbon wheels are filled with hard foam, so technically they are solid, I suppose.
You've got this arse about face. The clue lies in the word observe.When it gets all technical and scientifical like this I can't follow. Is the plumber under the sink there to observe the crack in my arse or am I to study his?
Well, it is easy to figure out. Firstly, carbon doesn't crack in little bits like metal. It is either cracked or not. Cracks will happen not mid-section but at intersections and a quick inspection of the paint will reveal all. Secondly, a cracked carbon frame creaks. Thus, remove all wheels, chains and other semi-loose bits. Now find two strong blokes to manhandle the frame. Bend it this way and that way, pull on the fork, push on the fork etc etc and listen. Then, since it was rear-ended from the side (if that makes sense), put the wheels and chain back on and put the cranks in the 6 'o clock position, stand next to the bike and push hard on the crank with your foot, in an attempt to make the frame flex sideways.
If it passes this test, it is OK to go.
That's a nice example. However, it is quite easy to repair actually. I've fixed plenty of such breaks with excellent success. Carbon is very forgiving to work with and no different from fibre glass in that aspect.This is spot-on. The resin that makes the shape of a carbon frame is relatively weak and easily damaged by impacts from the wrong direction. However if you stress it from the intended directions, as designed, it is massively strong in the same way as concrete reinforced with steel rods.
The notion that you can x-ray a frame is twaddle - what would an x-ray show and where would you find someone with a machine they were willing to allow you to use? The hard glossy paint used on bike frames cracks easily and will show any damage.
This is my cycling buddy's right hand chainstay, which was crushed after he had an unfortunate meeting with a car. The bike bounced off the plastic front of the car, flew over my head and landed on top of a high hedge ten feet behind me. The brittle plastic has fractured but the carbon has held it together. Squeezing it shows that it crushes easily and is clearly a write-off:
I can't decide if this is the funniest thing i've read this week or if you tipify everything that is wrong with the internet.What no one has mentioned is that you must try to locate any cracks immediately, otherwise the moisture in the atmosphere will cause the carbon to melt together again. Unfortunately this usually only covers up the crack on the surface, disguising the unsafe flaw underneath.
To check for cracks in a frame that has been exposed to moisture after an accident have your frame looked at closely by this chap -
Then get an opinion from this mob.
If the cat scan and the lab report are OK the frame is safe.
The latter. It has humour and lore blended into one deadly package.I can't decide if this is the funniest thing i've read this week or if you tipify everything that is wrong with the internet.
Engineer a re-route or, insert a little tube and do a single bypass operation.I think I understand that! The only concern is that the rear derailleur cable runs through that tube.
Shouldn't be a problem, if you have a look through the link I posted, the repair to the booms on gliders also house the control push rods too, so if you used a bladder, then you would still have a void for the cable to run in.I think I understand that! The only concern is that the rear derailleur cable runs through that tube.
No, don't be tempted. It will be difficult to align the bike properly and it may walk like a crab afterwards. But more important, that area is under a lot of stress and a failure is catastrophic. A failure on a chainstay or seatstay is survivable.
