arallsopp
Post of The Year 2009 winner
- Bromley, Kent
Most of this has been covered now, but incase you're short of a final £0.02, here's my contribution:
When I started to ride clipped in, I found I could start the power stroke earlier (pushing across the top of the pedal) and finish it later (pulling backward at the bottom). As both feet did this (even if only at 5% power) the dead spot when the cranks are parallel to my legs was removed. Less stomp left, stomp right. More push/pass/push/pass
As time has gone on, the power transition from left to right pedal and back has got neater and more fluid. What was a pole became a triangle, became a square, became a circle.
I only really spotted how much push I give across the top of the circle when I failed to clip in properly a few weeks back. Foot went rocketing off the pedal in a most unexpected direction.
Worth saying I'm on a 'bent, so am 90 degrees off the normal riding position. YMMV
