Cyclopathic
- Leicester.
1. When buying your tin of Nitromors in the hardware shop move straight past it and find another brand. I have found Supadec to be the best.
2. If you have any Nitromors in your workshop ignore it completely and use Supadec or something else.
3. It would greatly improve the efficiency of your Nitromors if you chucked it away in an environmentally responsible way. (Although it's so bloody weak I doubt it would have any adverse effect on anything it came into contact with. I'm tempted to see if it works as a refreshing cordial)
Honestly I had used supadec before and thought that one day I'd go the extra few quid and get Nitromors. I thought that it was supposed to be the absolute nuts and that if the supadec I was using was pretty good then Nitromors must be out of this world. It is not...It is rubbish. It makes a hell of a mess and takes about three goes to get all the crap off that supadec does in one go.
I would advise that with supadec you leave it on for an hour to an hour and a quater rather than just the 30 mins advised but if you do it will not have all dried up and dried the paint back on to the surface and it will have bubbled up nicely all the paint you have applied it to.
Do be careful not to get supadec on your skin of course, as it does tend to burn after a few seconds.
What really boiled my spuds was that the Nitromors said it was a new more effective formula. I can only assume they mean more effective at making them a profit because they are using less active ingredients.
Rant over.
Rant over.
