ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
Funnily enough, I was doing this about an hour ago. I couldn't remember if the ridiculously wide-range cassette that I have put on my CAADX started at an 11 tooth sprocket or a 12. (It's an 11.) The tooth count is clearly visible on each sprocket.
Anyway, I finally sorted out the indexing of the new gears and am about to go out and test it so I can't hang about here all day gossiping! (The new XT 'Shadow' rear mech appears to be really sensitive to cable friction so I had to use the minimum possible length of rear outer, lube the cables, take a pair of links out of the chain, and adjust the B-screw ,as well as very carefully tweaking the inline cable tension adjuster. I have got the system so it shifts up and down over all 10 sprockets when in either ring, but it is borderline on a couple of shifts, so I foresee problems ahead if dirt gets in, or the mech spring loses tension.)
