Yellow Saddle
- Loch side.
No, I really didn't. I just thought it was obvious what @lpretro1 meant and the reply was both pedantic and deliberately misreading "bearings" as "balls" to make its claim true. Nothing was written about crushing the balls.
Either be a pedant or don't, it's all the same to me, but pedantry means you should be called out on misreading other posts.
I'm not perfect and have misread posts in the past. I'll grant you that I substituted balls for bearings but I did it so that I could give you an easy challenge to disprove your claim. It is easier to attempt to crush a single ball on an anvil than an entire bearing. But do try any of the two. The result is the same. They are made from the same material and are both equally hard.
I want to make three points:
1) Over tightening the skewers will crush neither balls nor the cups or any other bearing parts. The skewer lever will break off long before the bearing material yields.
2) You almost cannot over-tighten a skewer. It needs to be so tight that it is difficult to remove.
3) Badly adjusted bearings cannot cope with properly-tightened QRs and fail. However, it is the adjustment that's at fault, not the skewer user.
