winjim
If it helps, the rim brake version of that Buena Vista frameset I posted has 132.5mm spacing, the idea being that you can fit either 130 or 135mm hubs. So they must be able to take some flex, although in this case it's only 2.5mm rather than a 6mm cold set.I want to pull mine out from 120 to 126 so I can actually find some alloy wheels to fit! But not sure if the mixte design would tolerate that sort of thing...
