How often do you clean your chain?
London
9 speed chains also call for single use special link. At least my kmc did, and skimping on replacement after clean sponsored me a looong walk home with chain in my pocket...and bruised balls...:cursing:
Can't see the need for even 9 speed really, 5 speed was enough for most of my riding:blush:
SRAM 9 speed links can definitely be re-used, though have recently moved away from after some rapid wear. I thought some KMC links could be re-used at 9 speed. Am using KMC at the moment. I would personally always avoid chains with links that can't be re-used. Have only ever had trouble with a link once and I think that might have been caused by the stupidly long pannier straps on a pair of my ortliebs.
nickyboy
Norven Mankey
oil every 100m or so
Sounds a tad excessive, stopping every minute or so to relube the chain but whatever works I guess
tyred
Ireland
What's this chain cleaning of which ye speak?
612336
Glow worm
Near Newmarket
Years ago, I somehow got into the habit of checking tyre pressure and cleaning chain once a week, normally Sundays after a ride. Mickle method applied here too.
I also wipe jockey wheels clean and use a v. small flat headed screwdriver to get any crud out of the cassette between rings.
T4tomo
Wipe with a rag (and GT85 if wet) after every ride and a quick re-lube (wax lube).
full on mickle maybe monthly
dodgy
We had a thread on here years ago, might have been MANY years ago when a newbie came in to tell us all about his amazing park chain cleaning tool, you know the type, the ones that result in about half a pint of toxic juice to dispose of sensibly. He got told about the mickle method and was having none of it, the thread went on a while and he eventually relented, gave it a go and then apologised and dumped his chain cleaner :laugh::laugh::laugh:
I use an old flannel/tea-towel with 'red' diesel on it, after a wet ride (or a dusty one, if on bridleways)
Failing that, weekly, if it's reasonable weather
Once a month, the rings are taken off, & cleaned, as are the jockey-wheels (& cage internal face)
The chain goes into a bowl of diesel at that point, maybe scrubbed with an old toothbrush
Then it's dried, & re-lubed with a mix of cheap motor-oil & diesel
It's all worked fine for me, for a number of years
NB; I tried diesel in a couple of the chain-scrubber devices, but it 'eats'/mis-shapes the plastic after a while, as though they belonged to Salvador Dali!
Ming the Merciless
There is no mercy
Inside my skull
Yep 9 speed links can be reused quite happily
mustang1
London, UK
When I commuted, then every 2 weeks in summer or every week in winter.
Now I just ride for leisure so uhm, maybe every couple few months or when I hear the chain making noise (I don't ride in rain any more).
