cassettequestion
I have a 10 speed on the back and compact double on the front.
Took it to the bike shop to set up the gears because I couldn't do it. Had a little ride around and found the chain rubbing against the front mech when I was using the big cog on the front and 7th biggest on the back. I took it back to the shop and they said that was normal and that I should only expect to use the smallest 6 on the back. To be honest, this is being conservative as well as I'm sure it was rubbing in anything but the 5 high gears on the cassette..
My question is - is that correct? I do understand you're not supposed to use a big to big or small to small combination but telling me I can't use pretty much half the gears seems a little off to me. I've had other road bikes before and tended to ride around in the 2nd or 3rd biggest gear on the cassette when on the flat and didn't notice this problem.
Grateful for any help or clarification. Thanks.
