How much is to much.
Brandane
Costa Clyde
Thanks for editing the thread title. It was making me itch.
Yes; me to.
Brandane
Costa Clyde
At what point do you say bike just isnt worth it?
Thing is though, if you plan to replace it with another second hand bike, you are back to the same problems re not knowing its history. You might end up with more issues, perhaps the same or different to what you have now.
This is why I like to keep bikes for the long term, even though I have mostly bought second hand in the past. After a while you know when the chain and cassette was last changed, gear/brake cables inners and outers too, wheel bearings, bottom bracket etc.. (Actually, to confess I am a bit OCD in that I keep a written record of replacement parts; it makes life easier when you have 6 bikes!). That way, if something goes wrong, you generally know where to start looking. Rather than blindly replacing parts which might be perfectly good.
So my opinion is - get it fixed, and keep the Giant.
Marchrider
Interesting niblet about reversing the cog on the cassette - how does it affect the gear changing?
I have never noticed any difference, may be we have all been sold a pup with these fancy ramps to make changing easier?
Someone did tell me once the ramps are to help changing down a gear (up the cassette) whilst at full power on a hill. And I would never do this as it seems wrong and likely to cause problems
Would it even work? Aren't the freehub splines assymetrical? I've never tried to put a sprocket on the wrong way round, but this picture suggests that it wouldn't fit unless you took a Dremel to it. There's a big "anti-spline" and a little one next to each other (z in the diagram) and they'd be the wrong way round to mate up with the spines if you flipped it over.
As usual - I'm probably wrong. And as noted, I've never tried it
you need to file a little bit away, just the bit to the left of the positioning marker in this photo, then it will go on flipped over
here is an old one that has no doubt done a lot of miles in both directions, so to speak
now think about the chain turning the bottom sprocket clockwise, that is quite an easy slope for the chain to slip up, now compare that to if the chain was turning it in the other direction, the chain has something to get a bit of purchase on
Seriously it works, and if you're a bit of a skinflint like me where every penny is a prisoner. Then it is worth trying. Esp if you have just fitted a new chain (this is where a bit of slipping is first noticed) and it is just slipping in one or two gears, flip them over and you will probably get the chain out of it.
presta
If by "won't index" you mean false changing, that's caused by worn pivots in the derailleur parallelogram. Give it a waggle, it'll be obvious if they're worn.
wafter
Oxford
That's an interesting thought - I wonder if that might be what's responsible for my elusive shifting issues on my Fuji....
wafter
Oxford
you would think on third local bike shop. Taken in to two, bike was worse than when I had taken it in. One was so bad actually refused to take it back, have the feeling I was ripped off. i wont mention them other than to say they were Sh*t.
Sadly I've had similar experiences in the past.. The exception was Warlands who were very accommodating of my Brompton's recent hinge problem (and did the repair to a decent standard) however back before I resolved to stop using bike shops pretty much every one in the city had been boycotted for some reason or another.
november4
Worth having a go yourself, doesn't take long and this guys videos are good ref
Agree with others, maybe the derailleur hanger is bent, and optislick cable, but new cassette is relatively cheap. Depending on which cassette/ wheel, the installation may need a spacer, which can cause shifting errors if not installed. Google will have answer. Good luck. I just built a defy frame up with spare parts for winter trainer using 105
View: https://youtu.be/GmBEAg_vNRg?si=9qGN_5fdeLoEYNxD
