slowmotion
Quite dreadful
- lost somewhere
I'll try again. Our oven has a 2600 watt element. If I set the thermostat to 130 C and turn it on, it comes up to temperature in about 8 minutes. It takes a few minutes to settle down, but within ten minutes it's cycling at one minute on, five minutes off. It will do that for as long as it takes. The fan runs all the time of course. I guess that the fan is about 70 watts. That lot adds up to an average continuous load of about 0.5 kW. If you want to cook a bit of piggy-wiggy for seven hours, that's going to be about 3.5 kWh. At say 17p per kWh, that's about 60p in cooking costs. Of course, things will be a bit worse than this because your slab of pig introduces some thermal mass into the equation, rather than the empty oven situation that my illustration is based on.So, to summarise the responses thus far: no-one has a clue.
Thanks everyone.![]()
A quid, tops.
