bike_the_planet
- Perth, Western Australia
montage said:Ok....somebody stop me before I go mad with this...
But is carbon tubing expensive?
And are all the metal parts such as dropouts, BB cage etc possible to get/cheap?
Will I die if I do this?
I ask because I saw this: http://www.cyclechat.co.uk/forums/showthread.php?t=27899
Carbon fibre does not come in standard tubes. This is because carbon fibre does not have isotropic strength - ie it is not strong in all directions in the way that steel, al and ti alloys are. When you build using carbon fibre you have to build it as a complete structure and not as individual tubes joined together as with steel etc.
This is why many carbon frames almost look moulded in a fluid sort of way rather than tubes joined together.
Most people assume that carbon fibre is 'stronger than steel'. Well it is in tension (hence the claim that carbon's ultimate tensile strength is better than steels). But in compression it is weak. It's impact strength is relatively poor. This is why you have to carfeully consider the type of stresses that are present in a bike frame and build the frame accordingly.
That's why many modern carbon fibre bikes are built as monocoque structure.
Carbon fibre's other achilles heel is it's failure mode. Most metals have a failure point well above the yield point (the point at which the material deforms). Steel's a classic example - stress it too much and the early warning sign is that it will bend - permanently. But you have to stress it alot further before it will snap. Carbon doesn't do that - overstress it too much and it just gives.
If you want a carbon fibre bike - just buy one...
Tony
