Even with clipless pedals almost all of the force is applied during the down stroke.
Chapter 2.4 of this thesis suggests their may be a risk of injury by trying to adjust the natural pedalling motion (recovering on the upstroke).
One plus with clipless is that it keeps the ball of your foot in the optimum position at all times where the trainer on flats does shift around at times.
If I don't use any concentration I tend to mainly push down during the pedal stroke. If I think about my pedal stroke and use the push forward, push down, pull back technique then my speed increases by 1-2 mph. My cadence does not increase and I do not change gear.
But wouldn't it use slightly less downward force meaning those particular muscles may get a little less tired giving more energy for faster cycling?Sadly, what you have described is physically impossible. If your gearing is the same, and your cadence is the same, then your speed will not increase. Think about it.
without changing the gear ratio or the rpm, how is it possible to increase the speed?
