dodgy said:you need to avoid the puddles.
dodgy said:Chain cleaning contraptions are gash. An old rag is all you need, as long as you can spare the 30 seconds it takes after every ride.
Dave5N said:Bollocks.
I clean four bikes every week. Or twice a week, sometimes.
The Park chain cleaner is exceptional.
Kirstie said:In this order:
Hose with thumb over the end
Muc off distributed with a variety of special shaped brushes
Leave for 5 minutes
Wipey cloth
Take chain off, soak in paraffin, rinse off, hang up to dry (when I can be bothered)
Rigid Raider said:Fit a proper Hozelock trigger spray on the end of your hosepipe to avoid wastage and because the water is freezing at this time of year. Buy a hand brush (the sort that goes with a dust pan) and rinse the dirt away while loosening it with the brush.
Dry and lube the chain. Make tea and relax.
simoncc said:MTB maintenance is absolutely essential. An expensive bike will very quickly disintegrate into a heap of worthless metal if you don't maintain it. Unfortunately it will disintegrate into a heap of worthless metal only slightly slower if you do.
