- London
Agree with this.Top tip, always make sure the drive side cones are done super tight, and never touch them. Then adjust from the non drive side. If not tight they will turn ever so slightly.
I replaced the back axle six months ago because it had a very slight bend in it. I went over a low hydrant cover on a bit of fast downhill which made a fair old jolt.
The new axle is still perfectly straight when extracted, but I wonder how straight it is when it's actually under load?
Never known tools to come with a bike.Raleigh. They are the ones which came with my bikes.
All good bikes used to come with a toolkit. They also had a little bag fixed to the rear of the saddle in which to store them .Never known tools to come with a bike.
Was it Wartburg that old east european car that used to be advertised with a free tool kit?
I'd get some different ones.
Xtools (are they branded Lifeline now?) are OK - also others.
Doesn’t matter on the quality of the hub. The first set I always wonder if I can improve on it and always try. 5 attempts later I might end up at the startOr we are using better quality hubs.![]()
The rear wheel runs dead centre of the seat stays (to the millimetre) so I'm pretty confident that the dropouts are good.If you've bent an axle in the frame it's likely that the dropouts are now misaligned.
I did that with a gear cable.The best bit is spending hours getting it just right and then spotting the new set of bearings still in the packet !![]()
The alignment of the rear wheel in the frame is not a measure of how parallel the drop outs are.The rear wheel runs dead centre of the seat stays (to the millimetre) so I'm pretty confident that the dropouts are good.
What I see when I look at the cups (back wheel off, bearings removed), is that the polish mark (where the bearings press) is wider on one side of the drive side cup than the other.
At the moment, all I have to do is re-tension the bearings every five hundred miles or so but it's still a proper pain in the arse to be honest.
I get a few hundred miles of perfection and then an annoying clicking sound at high speed as the wheel starts to wobble a bit from side to side.
