- Inside my skull
Does no one use a scanning electron microscope to check for chain wear?
Of course it does - a worn chain will not sit exactly where they're optimally designed to on the cogs thus each movement causes more wear. Go through three chains and you've probably worn the cassette too.I cant understand Halfords telling me to change my cassette at every 3rd chain though, or maybe they don't realise I only got 700 miles out of my chain. If the chain has worn at 700 miles like mine has does that affect the cassette too?
Why a steel rule[r]. This often crops up and the material of the measuring stick is always specified, which I find interesting.
Are the manufacturing tolerances in plastic rule[r]s so poor that the errors introduced are greater than those from eyeballing a measurement of an oily chain? Or is it a question of durability? Environmental friendliness? Or is it something bizarre and cunning like the expansion/contraction of the steel rule[r] will match that of the chain?
My Blundell Harling plastic ruler over-reads by 0.5mm at 300mm compared to my steel engineers' reference.Fair point, I'm sure if I had a 45-year-old plastic ruler instead, it would do just as well.
How often do you lube your chain? I clean and lube my chain once a month atm. Also, is 2100 miles about right before a cassette change?
I use the chain tool and it shows it was worn at 700 miles.
I'm not meticulous about chain maintenance but do make sure it is never dry...….Life is too short to spend prolonged periods of time cleaning a chain.
The old guy at my LBS told me to pull the chain from the front of the large chain ring. If you can see a whole tooth, change the chain.
I get 1500 - 2000 miles per chain on the road (8 speed transmission). I'm fairly good at keeping it clean and oiled, either every couple of weeks or after a long wet ride.
On the MTB I've stretched out chains in 500 miles before. Don't know if this is due to water/mud or more the very steep slopes and low gears with a bit of cross chaining thrown in for good measure.
The chain cleaning method I like the most by far is the mickle (search this forum), have tried other methods and found them either ineffective or faffy.
