02GF74
On my disc bar roadie... QR on left on rear... QR on right on front.. due to the discs.
how can disc rotors possibly interfere with the Q/R lever?????!?!!?
how can disc rotors possibly interfere with the Q/R lever?????!?!!?![]()
And what happens when you've got them lined up? Do you just stop cycling?i always try to align my chain link up with outer fr chainring so they match
no i try to calculate how many revolutions it will be before they re align themselves , this cycling lark is hard workAnd what happens when you've got them lined up? Do you just stop cycling?
no i try to calculate how many revolutions it will be before they re align themselves , this cycling lark is hard work![]()
I reckon he'd cycle into a parked car before he's calculated accurately.And how many?
i get confused counting after 3 so give upAnd how many?
Both my bikes with disc brakes have the QR lever comfortably on the disc/caliper side of the hub just as it should be. The wheels are also the 'right' way round, just as they should be. All this nonsense about the wheel being uni-directional is utter bunkum and will end badly.It's not the rotors it's the calipers.
EDIT: Just a point of order, the hub logo must align with the valve hole in the rim and this must then be aligned or 180° opposite to the tyre logos.
Not just beginnners, I'm afraid. Aye, and I plead guilty, as charged.That was not the first time I'd seen beginners with their QRs loose ........
On my disc bar roadie... QR on right on front.. due to the discs.
A word* of caution Ian.
I used to run my Dirty Disco like that but aftertwothree issues of the QR coming loose for no apparent reason (eg I hadn't removed the wheel or fiddled with the QR) I've turned the QR round and it's now on the left.
I'd put the QR on the right because I'd read somewhere that it helped reduce the likelihood of the wheel being ejected under heavy braking. I'm not sure where I read this.......
There was no obvious sign that the QR had come loose since the lever was in exactly the same place. It was the nut on the other side that had unscrewed. I wonder whether the rotation of the wheel had caused it gradually to slacken.
I'm using Hope QRs in Hope hubs.
The most obvious symptom that the lever was loose was a very dead sound from the fork if I picked the front of the bike up and dropped it on the ground.
It happened most memorably on the Friday's Tour this year, just before we climbed a steep hill. We went down the other side at high speed. Ulp.
Needless to say, I check the QRs very frequently now and I would never remove the "Lawyer's Lips" from the tabs.
* Sorry, that's lots of words.
