If it makes you feel any better I've just got through a square taper bb in about 4 months and a previous unit after 6months.
I put it down to my using sunrace units (though they have fsa bearings) and crappy conditions. The original Shimano un26 lasted 3years.
I ride everyday and commute on Northwest roads that are regularly salted, my front guard has lost its spoiler and I've not got around to replacing it. This means crappy salty water is thrown up onto the bottom 3" of the downtube and around the bb. I also rude the bike in lots of muddy gritty stuff.
The last unit failed giving no real noise, no wiggle but mainly lateral float, sufficient to start affecting shifting. Once removed I found it typically sloppy, rough and noisy between the fingers. With one of the bearings rotating on the edge of the unit.
After seeing yellow saddles recommendations on another thread I bought a un55 bearing. Appears to be better sealed around the shift.
Other than putting the cranks on wonky, you can't really mess up installation of this kind of bb can you?
