mac1 said:looks like my 23kg (48 pound) Kettler is the heaviest...
You are supposed to take it off the turbo trainer to weigh it
youngoldbloke said:What really matters is the responsiveness of the bike - the feeling that energy put in is being efficiently translated into movement. This must be affected by many factors other than weight - spoke tension, tyre pressure, bearing efficiency, drive train, frame material and geometry etc etc etc.
bike_the_planet said:I would suggest that all of the above are still secondary compared to the main limit on efficiency - air resistance.
Power required to overcome air resistance rises exponentially with speed. If you double your top speed from, say, 15km/h to 30km/h then you need four times the effort.
At 40 km/h 95% of your effort will be overcoming air resistance.
Unless your bike's in a really neglected state, nearly all your energy is successfully transfered to the rear wheel.
Cheers,
youngoldbloke said:That is pretty much a given - the bicycle chain drive is highly efficient. So what is it that makes one bike feel like riding a slug, and another one like a cheetah, if it's not weight, responsiveness etc.
