Drago
- Suburban Poshshire
You're getting quality confused with standard of design and finish.
I agree entirely. My titanium framed, carbon forked, Ultegra kitted out 'best' bike is worthy of a much better rider than me, but it really is a joy to ride. Even minor servicing like tweaking the gears or adjusting the brakes is a pleasure because of the quality of the components.
Other than weight differences, there is no performance difference between different cranksets. They all do the same job, in the same way.
Some claim benefits from oval rings, but that's more a matter of personal preference.
I upgraded from 105 to Dura Ace
I've got a £20 crankset from decathlon on my bike at the moment. It's not the thing that stops me taking on the hour recordI have seen many a post, by the usual suspects, on here saying "other than weight" they're all the same and then saying "weight" hardly affects" your cycling experience. It has been the same response, regardless of component. It's getting boring now.
I bet the culprits aren't riding the cheapest bike they can find though, despite that being the correct bike to have, based in their posts.
You're actually following your own logic though, in buying a £20 crank and believing all others wouldn't make any difference to you. That's fair enough.I've got a £20 crankset from decathlon on my bike at the moment. It's not the thing that stops me taking on the hour record![]()
So are you simply going to replace hers with another £20 decathlon one and leave yours as is?Not quite.... Mine was worn out and I got sick of the gear change so I took the one of my OHs bike as a temporary measure. About 6 months ago. She hasn't noticed yet, but I might need to put some cranks on her bike before we go on holiday![]()
I was thinking of putting my old one on hers tbhSo are you simply going to replace hers with another £20 decathlon one and leave yours as is?
Yes, the old 105 is the 5700 series. No problem with it other than when riding off the saddle, I got some chain rubbing. I adjusted my fd as best as I could but I never fixed the problem. Conclusion was that the crankset was flexing maybe 2mm.was that 105 a Hollowtech II version ?
Lots of crank stiffness data here.
Note that stiffness is resistance to deflection under load. If you don't have the strength or weight to deflect a crank, then a stiffer one will have no advantage.
Chainring quality does make a difference, to durability, shifting and stiffness (for big ring).
The Dura Ace doesn't flex or flex very little, not enough to rub on the fd. No need to adjust the fd at all. It's a little easier to move from one chainring to another but not a huge improvement.
Weight difference? I can't remember the difference but probably well under 100g. It's welcome as a whole saving....makes the bike 7.5kg which is not bad at all for a large frame.
Does quality make a difference? I think so. If you can afford it then go for it. I don't run everything Dura Ace because some components aren't compatible with my setup. .... for instance I like a large cassette and Dura Ace don't do a medium cage rd and my old 105 rd does a good enough job.
Did I notice the difference? I did but for a very short time then I just got used to riding the new components. I remember that I was very impressed with the braking power. If I had another bike with 105 brakes then I'm sure I'd notice the difference every time.
Does it make me faster? No idea but I doubt it very much.... I've never tried to measure the difference.
Why did I do it if performance gain is small?
I like good quality things without being stupid about it. I bought nearly everything second hand, in very good condition and at a fraction of the cost I'd pay for new.
I got the look I was looking for. Eliminated the chain rubbing, gained breaking performance and saved a bit of weight.
Would I do it again? Absolutely.
