How do you clean inside the links?
My chain has done getting on for 1500 miles since I bought the bike new in May last year, it shows signs of corrosion on the outside from all of this winter grit but I make sure I clean it pretty much every other day using a rag/baby wipe and lube with bike oil.
There is crud visible within the chain itself that a rag cannot get to and I would like to know how to remove it.
Would a wipe passed through each and every link be sufficient or would a full-on application of degreaser be on the cards? I am worried that this is shortening the life of the chain by being there by wearing it away quicker, I can hear a slight crunchy, grinding noise if I gently twist the chain.
Give it a really, really good clean, using chain cleaners and brushes. If its as bad as you say it'll probably take the whole can. It's not too hard to do though - mine got in a similar state once.
Once done, let it dry, and when it's completely dry, try starting from scratch again with the Mickle Method to keep your chain clean - search the forum to find it. :smile:
Redvers
France
Check the chain for wear with a chain wear indicator as it may well have worn beyond its limits and be quietly wrecking your cassette and chainrings.
In which case don’t bother cleaning it, replace it without delay.
If it’s still ok only a chain scrubber will do.
I’ve tried most of them, the best is the Park Tools one:
http://www.chainreactioncycles.com/Models.aspx?ModelID=8207
It’s a bit more expensive but the wearing parts are renewable and the cleaning fluid is pleasant to use and biodegradable.
I thread a baby wipe through each individual link and that seems to work. With the last chain only fitted last Fri (341miles old) the weather up until tonight has been fairly decent so I've just wiped down ever 2-3 rides (I'm using ceramic wet lube) and I've been very pleased with the results.
  • Like
Reactions: gaz
