Debian
- West Midlands
Thanks! (I think)
My Lemon had Brembos. Twats.GregCollins said:push the pistons back, all the way back, with a twist of a screw driver or other lever, whilst the old pads are still in situ
not as hard as changing brembo goldline pads on a laverda
summerdays said:Don't let your child help you when you are doing it... mine pulled the brakes on whilst the wheel was out.
Valy said:I changed the pads on my BB5s and it even though it was a bit fiddly, I got them in okay.
With hydraulic brakes do the pistons always try to push out, so you have to hold them apart all the itme while trying to change the pads?
Debian said:I wouldn't have thought so. They don't on a car. And if they did this normally the brakes would be applying themselves all the time.
The only way the pistons will push out is if there's some force acting on the brake fluid.
Valy said:So the pistons don't push out more when trying to change the pads? I mean not to the point where they would be touching the rotor, just pushing out because presumably the retainer/spring would need to be removed than pushes the pads away after braking? Is there such a device on hydraulic brakes even... ?![]()
Debian said:It's a good question.
All I can say is that the pistons on car brakes don't move out under there own steam, they just stay wherever they're pushed to. I haven't (yet) changed bike hydraulic brake pads but I can't see why the pistons should push out.
Valy said:Did you buy a whole new brake instead of replacing the pads? :S
Cubist said:My Lemon had Brembos. Twats.![]()
