28mm is the most variable if any tyre size.I'll try narrower tyres.
I just checked and the current giant tyres are 28mm and look bigger than the 28mm conti gp5000 I have on another bike. I'll get some 25mm continental and hope for the best.
That's not the issueSaw a few mm off the brake blocks ?
Yeahbut I guess the reasoning is that a few mils off the blocks would pull the calliper a little higher but it would be very marginal.That's not the issue
How?Yeahbut I guess the reasoning is that a few mils off the blocks would pull the calliper a little higher but it would be very marginal.
As the width of the blocks decrease the underside of the calliper raises slightly. You can check this on a side pull brake by removing the wheel, undoing the cable and squeezing the blocks together. As you squeeze you’ll see the underside of the bridge raising slightly. This is what I assume @DaveReading was meaning.How?
Good shoutIf you have a wheel/tyre from another bike, might be worth swapping to see if clearance is improved.
You could perhaps just stand the bikes side by side and use a spirit level to span the tops of both wheels. If there is a significant difference, it might show up.The wheel from my other bike currently has conti gp5000. But has a disc brake. Will it fit even just to see the clearance?
Just change the tyre not the whole wheel?Good shout
Bear in mind that tyre width tolerance is ±3mm, so you could find that an oversize 25mm is bigger than an undersize 28mm. Here's the difference in size between a pair of my Marathons that are both nominally 35mm:I'll try narrower tyres.
