fair weather cyclist
Hi guys, i'm having a wee problem with my partner's bike. The clearance between rear wheel/tyre and the rear rim brake is minimal, I'd say no more than 1mm, which makes it a problem when little pebbles get caught in the tyre as they scratch the brake. You can see below (bike upside down) all the black paint has come off.
This is the brake, it's a tektro so not great but good enough (eventually I'll buy a proper 105 brake set). Is there anything I can do to increase the clearance? Any of those wee bolts I can tighten/loosen/play around with?
This one instead is the front brake and as you can see (barely, apologies for the bad quality photo) there's plenty of clearance so no issues there.
Last thing, the tyres are 28mm which I think are a bit of a stretch for rim brakes, regardless of what the Giant website says. In the absence of other solutions, would switching to a 25mm tyre improve the situation?
